pr3-3 head
  • pr3-3 head
    can someone tell me if this is b16 type r or b18 type r. also what year would it be from?
    It can be b16 itr or Ctr... if its a type r head there is usually a green paint spot near the dizzy.. besides that no real way to tell.. I say take your came get the measured and you'll know what you have
      Like mantyme said. It can be any of those. If it's all oem. Check for dual valve springs, see if it has itr valves, cams, ports. Shit like that.
        Bump yeah cause I want to buy my intake Mani so idk how to go about what would it fit like what model and all that
          all b16 and itr and ctr are the same bolt pattern for the intake mani.. gsr is different... sooo you str8 as long as it says pr3.... you know you need to order one for a b16
            Thanks bro
              p33_3 type r p33 b16
              96 ACCORD FRESH LOWERED WITH POLISH FOR TRADE FOR 5 SPEED
                fail
                  wht valve spring it has? i was ytold dual sspring itr songle spring b16 dont quoat me
                    wtf bro?
                      Just uploaded a pic hopefully it helps
                        I just found out that a pr3-3 head come on a 00 Si b16a2 motor...the only way to find out it the ports are ported and if it has the right cams in it.the itr are a 240 lift and the Ctr cam's are 243 lift in the cam lobe..hear this will help
                        B-series VTEC cam specs These b-series cams will work in most b-series VTEC heads like the B16A, B17A, and the B18C. Type: Intake Lift: Intake Duration: Exhaust Lift: Exhaust Duration: Crower 63400 10.72 mm 234 @ 1mm 9.60 mm 234 @ 1mm Crower 63401 11.38 mm 249 @ 1mm 10.54 mm 240 @ 1mm...
                        I<3my EJ8'CoUpE
                          ^^^ and If the valve train has the better set like duel valve spring ect...but that green paint being on it wear off after awhile can't tell after so lone,unless u just got a new crate swap from one of the depot..outher then that have funn..u should be able to tell by the cam tho it's is simple as that..I had one and all I had to do is chex the cam and springs nuff said..
                          I<3my EJ8'CoUpE
