Was thinking about doing a b20v turbo but thought alil longer and I was thinking about rebuilding my ls for turbo I'm kinda at a loss for which way to go the ls turbo would be cheaper cuz I would just b replacing my internals for better new ones it on with the question I have to replace my pistons,rings,crank? Cams cam gears, valve springs rods lifters and wat else do I need to do for 15psi?
LS build question
Really with a stock ls , you can run 15psi ,, juss like tha'd , but if you wann do like a lil semi build or whatever , I'll go with Lsv , pistons , rods , new bearings , & b vtec head & oh yea headstuds , if you wann build your head then , the basic steps , supertech valves & springs & some itr cams with a aem camgears & a tune . . :) it'd all on your budget range as well . .
- tha range is about $2000.00-$2500.00 , head & block lil built .Last edited by 94EJ1OwnS; 01-18-2012, 07:26 PM.98Ex DD EJ8 ROADRUNNER
