gsr problems
  • gsr problems
    I got a 95 gsr in my 89 crx did a full tune up but everytime I pull the wire out of the 3rd cylinder it doesn't want to shut off like the others but i have no check engine light and vtech still kicks in . What would be the problem please help?
    Check injector clip and compression. You need fuel ignition and compression to run an engine.
    (860) and beyond
    #DavesTuning 8608050968
      x2 n from the sound of it ur running on 3 cylinders so i wouldnt be crackin vtec beatin the car in its condition unless u want the motor to break.. but like dave said make sure that cylinder is gettin spark n gas then check compression u could have a bent valve or bad rings etc... good luck
        Yea Iam not getting enough compression
          Now Iam just goin to build it
            Yea pull the head n check rings n valves n go from there...
