Arp headstuds B18c
  • Arp headstuds B18c
    Close
    I gota do tha same!!!! Good thread bro
      thanks haha
          i think factory recommended is 62 or 64. itll say in the instructions if you buy them new. i went 2 lb/ft over the recommended bc i was running high boost and didnt have any problems. with NA apps, factory specs should be fine, but a LITTLE extra wont hurt. on another note, i was running a SOHC, not a DOHC so it may be different. gl
            Its w.e. arp says
            Follow me @bolacan413
            Follow the build @k_insight
                according to all data, first step is 22 ft lbs, second step is 61 ft lbs.
                    bumpppp for 22 and 61 ft/lbs
                      bump i saw that somewhere
                        i did 20 50 80 it should be good its arp
                        Carefree-Living
                          Lol not exactly, but I usually do 3 step too
                            3 steps is a a deff but if you google or look on other forums its probably close to what i do
                            Carefree-Living
