whats up guys, so as some of you know im puttin my b20v in my hatch very soon. my clutch and flywheel just came in so now i have everything i need. well when i went to mount up the flywheel i come to find out one of the threads on the crank flange is stripped -_- im guessing who every took the motor out of the last car it was in had the flywheel hanging on this last bolt and it stripped it on the way out. ive tried several different bolts in the hole so i know its not a stripped bolt. Ive done my research and im pretty sure i need a 12.10 size tap which apparently is fucking hard to find. So my problem is i have no idea where to find this tap and im wondering if maybe anyone can do this for me?? this is literally the only fucking thing stopping me from putting my motor in. Oh and its only the top few threads that are stripped. not like the whole thread or anything.
Help!!! Stripped thread
Well sense the whole thing isn't stripped try to find that size/thread bolt. Go with that tho. But I do know that the auto trans flywheel has shorter crank bolts so try using 5speed bolts? Idk what tranny it had before so u might get lucky
Originally posted by Santi View PostWell sense the whole thing isn't stripped try to find that size/thread bolt. Go with that tho. But I do know that the auto trans flywheel has shorter crank bolts so try using 5speed bolts? Idk what tranny it had before so u might get lucky
Originally posted by Santi View PostX3 for hf. Good cheap tools but I doubt they would have that thread
