Vacuum leak
  • Vacuum leak
    I have a leak somewhere Trying to identify where it's coming from. When I try to hold a steady rev it sounds like I have a 2step, I've bought a new tsp and cleaned the iac numerous times so I also need help with this
    Damn no bumps or help
      Try to find at least the area it's at and spray some gas around the gasket. If u have a leak the motor will rev a little high
        It does cause as soon as I put my foot in the gas and hold it at 2000 it goes ramramramram (horrible effects) but you get the general idea
          Well by spraying it down u can find where it's at. Or feel around with ur finger and when u find it it will rev normal
            Hmm thanks bro
              Np gl
                r u using stock ecu? i had a smimular problem n i kept doing vacum checks just to find out the ecu wasnt giving enough fuel to my gsr n it caused a vacum effect
                Text:8604810204
                  get a can of break cleaner and spray it all around the intkae manifold and throttle body ..and listen for the motor to die down where your spraying ..... also if you got rid of crusie controll check the little nipple off the back of the intake manifold make sure its pluged.....
                  EM1-860-CTmember..1...
                  J-SWAPS ....860-457-8335
                    did you recalibrate the tps when you put it in?? or you just copped another throttle body??
                      X2 or carb cleaner [QUOTE=coupejordan27;1078212]get a can of break cleaner and spray it all around the intkae manifold and throttle body ..and listen for the motor to die down where your spraying ..... also if you got rid of crusie controll check the little nipple off the back of the intake manifold make sure its pluged.....[/QUOTE]
                      ebay ~ Made
                        x2
                          Put a turtle in your bay. it'll tell you if theres a leak or not. worked for me.
                          Down Since 09 ...
                          Mugen Inspired DC5
                            Lmao
