jdm gsr into ek troubles....HELP!!
  • jdm gsr into ek troubles....HELP!!
    so i took my 98 civic ex and bought the jdm gsr swap off of a member up here and it seems like it doesnt wanna run right in my car....the swap came out of i think her name up here was miss jdm im not sure but i know she had it in a del sol and the car was turbo...im not sure if its something wrong with the computer or if its the motor giving me problems..the car starts and runs fine but when u put it in gear and try to move the car it shuts off...im not sure if the computer is lookin for sensors that are not there l(crank position,etc) ive tried a few different computers and they all end up doin the samething..now i would really like to get this thing out and runnin good but its pissin me off so bad that i wanna sell it so if anyone can help lmk 203-508-5916
    any codes? i know it wont have a crank but u can bypass it with the harness. google it cus i dont remeber it. is it in panic mode?
      i did a jdm obd1 swap in a ek. but the crank didnt give me problems. just a cel. i still the the bypass tho to be safe. didnt make it run different tho no panic. check you map tps and iac tho.
        its throwin a code for an o2 sensor and another one for the crank sensor i believe
          i tried doin the bypass but that didnt work
            check for compression
              What ecu are you using?? Obd1 or 2a,2b
                i got a obd2a gsr ecu and 2 chipped p28s wit the stepdown harness
                  what would the compression have to do with it??
                    Lol I was boutta say the same thing its something in the ecu/sensors
                      Bad ecu?
                      Originally posted by LS/Vtec
                        follow those carefully. if you are running obd1 with the step down it wont even look for that sensor the trick only needed on obd2. so it idles fine but if you put it in gear and try to move it it just stalls?
                          It's called (limp mode) for future reference just sayin nd gl bro
                            as far as u know the motor could be complete garbage inside. its good to make sure
                              same shitt..............
