I got my car running. It ran ok. The fuel pump is pumping, and im getting fuel all the way to the rail. But the injectors aren't letting it threw. They let a tiny bit thru but not enough. You cant even hear them spray fuel. I swapped ecu's, reset battery, re-wired injectors, relay(i think the one i swapped was good) and cant figure it out. Lemme kno asap. Thanks
91 Civic Hatch DPFI TO MPFI
OBD0 to OBD1 Jumper
OBD1 Dizzy
RC SL440's
No resistor box, all wires are spliced together.
The c ar ran fine lastnight and then wouldn't start today!
OBD0 to OBD1 Jumper
OBD1 Dizzy
RC SL440's
