idle issue
  • idle issue
    When the car is just siting it idles normal but when driving an I come to a stop sign red light etc. The idle drops an bounces low to the point where is shuts off. Sometimes it starts right up other times it needs to be pop started. Any ideas
    Ef hatch sold
    Db7 blew up
    Em2 sold
    Db1 traded
    Ek fodo daily/project
    Yea try removing your iac valve which is located rite behind the intake manny and making sure you clean it out good if that doesn't work then you might need to buy a new iac sensor..
    CT-OUTLAWS
      What should I use to clean it I looked it up an it said that your better off buying a new one instead of trying to clean it out
      Ef hatch sold
      Db7 blew up
      Em2 sold
      Db1 traded
        Wat I found was best to Clean it out is brake cleaner does a good job sometimes if it doesn't work after cleaning it ur gonna have to buy a new one ..
        CT-OUTLAWS
          try carb cleaner since your actually cleaning carbon build up
          My transmission's went 9's
          http://youtu.be/z2PHemIp_Tg
            or carb cleaner^ also also check ur vacume lines i had a open vaccume on my car when i first started it and it didnt soudn any diffrent at idle but when i slowed down it would shut off
              Checked all the vaccine lines an it still does t
              Ef hatch sold
              Db7 blew up
              Em2 sold
              Db1 traded
                Did u remove and clean the iac valve?
                CT-OUTLAWS
                  when using carb cleaner make sure the iacv is dry before putting it back in
                    Haven't cleaned the iac yet my next thing on the list
                    Ef hatch sold
                    Db7 blew up
                    Em2 sold
                    Db1 traded
                        Where u been at faglet
                        Ef hatch sold
                        Db7 blew up
                        Em2 sold
                        Db1 traded
                          and what is your reason for that?
                            Ef hatch sold
                            Db7 blew up
                            Em2 sold
                            Db1 traded
                              i mean u dont have to wait to let it dry if u dont want but it will b harder to start the car if it is still flooded with carb cleaner and ur car will run like shit untill it clears out thats all
