bubble wont start!
  • bubble wont start!
    So last Monday my car kept runnin out of gas due to a injector leak. I kept crankin & crankin cuz I was just so mad! Out of no where I tried startin it, it stop crankin. So I thought my battery died. When my boy came thru we hooked it up to jump start but nothin so apparently I fried the starter, when I go to put a new one, Ls & Gsr starter wuldnt fit! But a b16 starter fits!! Shits weird. For some odd reason a 90-93 Ls starter fit. But won't crank. Any help? Btw its a 98 Ls with b16 lsd tranny
    get this problem solved for my boy
      Damn I never crank a car like that knowing it won't start
      sounds like ur car is hurt bro
      Gl shit sux also lol if ur car didn't want to crank it could be ur coil in ur dizzy
      Happened to my girls car no joke worked fine one second then next nothing
      Thought she was out of gas cause the shit was under e but no we put 5 gal in it
      Finally I put a used spark plug on one wire nd grounded it on the vc no spark
      Grabbed a spare dizzy pulled the coil out put it in bam shit started right up
      Hoped that might have helped
        check ur timing belt u prolly broke it lol
          starter signal fuse in the under dash fuse box.
            I think the ppl bringing him the starters don't even kno what they got
              Good looks bro
              I'll check but will the cause it not to crank?
              Wuldnt it still atleast crank?
              ALL fuses & relays are good
                Does your cluster lights go on?
                ~StayinFRESHSINCE1982~
                SPUNKY MONKEY CREW MEMBER #1
                203 CREW MEMBER #33
                  triple check your fuses
                    dumb question.... did you disconnect the battery when u changed the starter??
                      No but they never did & it still cranked
                      I probly checked them 6 times in one day
                      yessir
                        got the same problem. i can hear the fuel pump come on, battery is good, all fuses good. wont even turn over, bump!
                          check the small little wire on the starter.... aka the signal wire.... if its ok then check wire with a voltage gauge to see if your getting power to the starter wire if so then somethings wrong with the starter its self.... start small could be a cut in the wire or wire connection is shit
                          EM1-860-CTmember..1...
                          J-SWAPS ....860-457-8335
                            I hate shit like this!! Its like the problem comes from no where
                            If anyome has a b16 starter that they are willin to come thru just to try then please hmu!
                              Will do...I need a good b16 starter just to test
