piston ring questions
  • piston ring questions
    a couple questions.
    Do i have to pull the head off of my gsr to replace the rings?
    if i pull the oil pan out and crank shaft can i pull the pistons out through the bottom ?
    my other question is i was told u could pressurize the cylinder to keep the valves in place when i change the valve seals.
    has any one done/tried this????
    bump if viewed please
      bump i would remove the head and get it honed b4 replacing the rings
        someone has to know the answers
          how hard is it to hone the cylinder walls?
            bring it to the machine shop so its done right
              X2 but it's better to take the head of and takethe pistons from the top and if u do chance change them it's good to have the crank balanced and shit An like mantyme said def machine shop so it's done right
              integranation member #8
                how much does that usually go for?
                  If your gonna replace the rings you might as well pull the motor out, throw a single in there in the meantime and do a completely fresh rebuild on the gsr
                    Depends on the shop you go too
                      im gonna do this shit this winter. just looking to see what its gonna cost
                        X76
                        Follow Me On Instagram
                        Jdmkid618
                          i think im just gonna get a beater and do it this winter
                            will type r piston fit on the stock rods?and will c5 rings work with the block ?
                            Last edited by ls94civic; 08-30-2011, 09:01 PM. Reason: i was too high and forgot to proofread
                              yes type r pistons will fit on your rods....
