If all it does is click when you go to turn it over how do you know you have spark?
Make sure your battery is charged, check the connection at the starter, battery post and battery ground. Then go on the the starter if all else looks good. sounds like something stupid
u need spark compression nd fuel to crank it over check all ur grounds there should be one to from engine to frame one from negative terminal to frame nd one from transmission to frame make sure the bolts are not all rusty nd corroded gl
There is also one that is the ground for the whole harness which is the ground that is on the thermostat housing
