Not to sure what the problem is....
  • Not to sure what the problem is....
    anyone have any input to what this problem could be? My ls civic kind of bogs down through rpms and then gets back up. Idles no problem.
    check engine?
    Follow me @bolacan413
    Follow the build @k_insight
      maybe worng ecu or timing is off
        Ur fucked. Junk it
        Originally posted by ct tibby
          lol
            if it bogs when your begining to drive off, could be a bad sensor...
              My car did that when I had a bad o2 sensor...
                it doesnt really bog,when your driving it if you get on it,it feels like you took your foot off the gas and back on real quick its really weird...any input he showed me this problem last night and i had no clue...
                  something might be clogged
                    i have the same exact problem on my dc2... blows dick
                    Current: 05 Type-S
                      like when your kinda getting on it it just feels like your off and on the pedal? like the fuel just shuts on and off?
                        ive heard i should do the timing to possible bad fuel injector, so im not sure lol
                          tuurn the car on hold rpm between 2 and 3 grand if the rpm jumps a little and is not smooth then its the tps.....throttle possition sensor....i got the same prob....either that or the map but i would say tps
                            bump..
                              is there a CEL ? i had the same problem , came out to be my 02 sensor , its was bad , it wasnt showing a CEL but as soon i unplug the 02 sensor it stop doing it . .so unplug your 02 sensors and see if it still has the same problem . .
                              98Ex DD EJ8 ROADRUNNER
