piston q??
  • piston q??
    I got a bare ls block bored out to 82mm which piston should i use for best all motor set up???
    an 82mm piston, and whatever compression you want
      Sry my question was more to what engine the 82mm piston come from
        lol
        if you want to stay on pump gas stay under 12:1
          Originally posted by V8-KILLER View Post
          lol
            some nippons they make 82mm ctr pistons
            eh9 jdm b16
            Pimpbays
              stock bore on a LS is 81mm. So when you have a 82mm bore, youre only option is an aftermarket piston.
              So you wouldnt use an 82mm piston from another motor. You would buy a set of weisco or CP pistons, for a 82mm bore B series.
                Thank you thats what i wanted to know
                  There are WAY more than the 2 companies i listed, so shop around. The newer forged pistons are all similar in quality to a point. For a normal street application, any major company will do.
                    Thanks gif the input very helpfull im going to be starting my first motor build so bare with me if so of my questions sound dumb i rather b safe than sorry
                      no problem. Its super easy to build a honda. Just pay someone else to do it. Jk.
                      Before you make a purchase, make sure your block is in good shape. If there is any scoring or defects in the walls, you should have it checked. Piston to wall clearance is vital to engine life. Most forged pistons require a similar clearence, so if the block was bored correctly and isnt severely worn, it should be fine. Spending a lil extra money now to have a machine shop check the bore and possibly other parts will save you time and money later.
                      Your going to save money if you buy a piston rod/combo. Eagle rods will do just fine. Find a LS crank that hasnt been tampered with or had a spun bearing and ur good. Just figure out what size bearings you will need (machine shop) and buy the piston rings that are recommended for the pistons you buy and your almost there.
                        Bore it to 84 mm u ll have a 2.0 than get 13.1 cp pistons
                        Follow me @bolacan413
                        Follow the build @k_insight
                          or just start with a b20 block.
                            What would be the difference between boring to 2.0 or just getting a b20?
                              nothing, but the b20 was designed to be a 2.0, and i would assume that the sleeves in the b20 are atleast designed different.
                              What are ur goals for the motor? Thats the only question that needs an answer.
