i have a 1990 crx si and i jus put an ls swap in it from a 1992 teggy. i converted it over to obd1 with rywire conversion harness. used my stock crx si harness and used the obd1 injector clips and dizzy plugs. i go to start the car, and for some reason there is absolutly nothign. all i hear is a click sound every time i turn the key coming from underneath the dash. the starter isnt turning over or anything. for some reason goin from the ignition to the rest of the motor there must be somethign wrong. i checked the fuses and they all seem to be fine. is there anything else i could check/look for b4 i go taking apart the whole wiring and tracing it all back to make sure its all hooked up right??
Starting problems!!!
You sure your starter aint Fcuked Up. B-Series cable tranny starters suck.13203
Originally posted by LS/Vtec View PostCould be a a missing ground, Or possibly your starter signal wire isn't hooked up?
