Smoking Problem
  • Smoking Problem
    THANKS IN ADVANCE FOR LOOKING !!
    Hey so when my car is on, i can pull the spark plug wire from my head without loseing any power and i have white smoke coming out of my exhaust. When i give it gas, more white smoke seems to come out, what could this be? And how could/would i fix it? thanks again
    And its only that one cylinder, The first 3 are working. The white smoke isnt antifreeze, i already fixed that problem.
      Gl I have an idea what ur problem is but I don't want to be the bad new bringer
        Ur fucked.
        Originally posted by ct tibby
          head gasket
            I had to be.. Some1 gotta tell him the deal
              Is it deff a head gasket cause i kinda just had that done. My mechanic maybe did something wrong? I was told it could be a bent valve or piston ring or something?
                Well you did say you were having coolant problems. If it was overheating from that then your headgasket could have definitely went. Doesn't matter how recent it was done could still be that.
                  And that would cause one of my cylinders to not give off any power at all?
                    Well if the headgasket is blown on that side yes then you can lose compression in that cylinder.
                      Okay cool, Thanks for the advice!
