B series swap into 97 ek
  • B series swap into 97 ek
    ok so im grabbing up a 97 civic lx and i want to swap a B series into it....i know the basics seeing that this isnt my first swap but i just want to get a few things clear that im a little shady about what im going to need exactly....motor..mounts..si wiring harness?...wich ecu is best...99 si shift linkage?...best axles?...i just want it clean and done right and for some reason i cant find a good step by step for a b series into an ek even though its so common
    U dont need an si harness use the 1 that comes with the car
    WILSON BUILT
      is you swap a LS GSR B16 you need mounts, si linkage...you can use a integra one but the integra one gets in the way of the secondary o2 sensor, b series axle, depending on the swap u can chose the ecu...for the harness you can use the 96-98 civic ex harness you don't have to rewire much for it... gl
        U can use the stock mounts an brackets
        WILSON BUILT
          The cars a lx I'm going to go either b16 or gsr....do I just add a wire for vtec on the stock harness
            The stock D mounts?
              Originally posted by artymillz View Post
              the stock d mounts?
              yes the stock mounts u will need a obd2a harness ex
              WILSON BUILT
                use your stock d mounts, tranny mount and rear mount, all you need is the rear T bracket, that needs to be 99-00si, any b series shift linkage and axels, then u need the timing built post side mount, 3 bolts that connect to the block and then there are two studs on top, and you use that stock mount as well. if u have a vtec harness already, it is perfectly fine, run a p72 ecu or p28 with a jumper harness to run obd1 and tune it.
                  u can't use the stock D series T bracket on the back and also you need the 99-00 SI post mount too...you can use the stock tranny mount and bracket and the rear mount...
                    I am pretty sure I said that in my post. Read it fully.
                      I have a b series in my ek I know what I am talkin bout
                        No you can get the stock harness wire for vtec , bcus finding a obd2a ex harness is impossible. .
                        98Ex DD EJ8 ROADRUNNER
                          i have b series in my ek hatch too....while i was writing ur post wasn't up yet so i didn't see it... and i know what im talking about too i've done it on my car and my boiz car...i also have those parts as spares looking to put in another ek....
                            lol. stock mounts are ugly. get hasport if you arent on a budget. otherwise listen to builtnotbought hes right.
                              Haha ight my bad
