lsv into eg?
Originally posted by kbrown! View Postok so i,ve got an eg with a single v in it! i want to upgrade to lsv. what do i need for this. obviously engine tranny ecu. axles? jumper harness? mounts?
i know theres prolly stuff on here that tells me but i have no ambition to looks it up! lol
also need the parts for this swap so lemme know what ya got.
search man...i don't think anyone is gonna post the entire process..this set up is old and has been covered numerous times on many other forums...
google is gonna be your best friend
if you have no ambitionto search, then ur still gonna rock the single v for a whileMidori green is so last year :)
You need B series 94 and up teg mounts 2 fittings 1 for the block 1 for the head oil line dash 6 or dash 4 Vtec head ( duh duh) beries shift linkage 94 and up teg gsr timing belt depending on how your single VTEC is wired you'll need to run A a sub harness made by hasport or B get a diagram of a Obd1 VTEC harness and run the pins directly from your harness 1 for the solinoid 1 for the oil pressure switch and 1 from the engine bay as a ground for your pressure switch that makes the vtec pop without a gay ass button. The swap has been around for a while and is really simple and you don't need a jumper harness if you run the pins like I said. If you need a hand or have any questions just ask aight
You can make some serious torgue it all depends on the tuner my friend I know someone selling a Built gsr head pm if interestedMoney Ain't a Thing! Crew Member #5
Originally posted by JDMEGVTEC View PostYou need B series 94 and up teg mounts 2 fittings 1 for the block 1 for the head oil line dash 6 or dash 4 Vtec head ( duh duh) beries shift linkage 94 and up teg gsr timing belt depending on how your single VTEC is wired you'll need to run A a sub harness made by hasport or B get a diagram of a Obd1 VTEC harness and run the pins directly from your harness 1 for the solinoid 1 for the oil pressure switch and 1 from the engine bay as a ground for your pressure switch that makes the vtec pop without a gay ass button. The swap has been around for a while and is really simple and you don't need a jumper harness if you run the pins like I said. If you need a hand or have any questions just ask aight
PM me if u want details#ctvtecfightclubgrandchampCTVTECSENIORCITIZENSCLUB
