need some help..
  • need some help..
    tranny is grinding at high rpm from 4th to 5th... and also wht should i do for mods on my b18 non vtec obd1 integra
    turbo or get a vtec head
    :cool:
      and get a new tranny
      :cool:
        throw some synchromesh fluid in there and if it continues to do it pm someone that works on trannys.
        knuckk.
          if i do the ls vtec build wht do i need to do it, i want to go all motor cuz every1 has a turbo car
            thnks about the fluid heads up
              Building an LSVTEC Building an LS/VTEC is not for the feint of heart or shallow of wallet, but it is worth all the time and money that it will take. In this article I will assume that you have read our recommended parts list, you have an understanding of engine building, you own a Helm's (or...
              knuckk.
                It depends on what u wanna do to it cams rods pistons etc and tranny try the fluid or gonna need it rebuilt
                JOE BUILT!!!
                  If its grinding, replace the Sleeve,Hub and synchro.. you should be good after that
                  Hondata 1st in the 11's, 10's, 9's, and 8's in CT 1992 Civic HB
