im stumped
  • im stumped
    So my car was running good..i get off the highway andall of a sudden it bogged and wouldn't go over 3500..its like neon stuck in 2step.changed rotor spark plugs.it sat outside my boys shop then bout half hr later startedit reved fine..switched to Gsr computer and feces fine..turned off and dtarteagain anbak to only 3500..if ya got any ideas let me know..plz ctv.
    Speedometer werk??
      sounds like dizzy
        dizzy,main relay,tps,map,
          Sound like dizzy!
          98Ex DD EJ8 ROADRUNNER
            X2
              Could be the map
                Tried a new rotor..but same thing..i will try new dizzy Wen i get outta work.
                  i had same problem, changed my dizzy and it was fine.
                    tps sounds like a good thing to check. if you got a DMM then check for volatage going to sensor and resistance (look up the exact specs for the resistance of the tps) if the dizzy doesnt do anything. could do same for the MAP sensor too.
                    VTEC is just way to much fun
                      No argument the dizzy when it get hot it stops working and then it cooolssss down it work fine happen to me good luck
                        when was the last time you change your oil?
