wont stay steady
  • wont stay steady
    So I when I rev up my car & try to keep it at a steady rpm it sorta looses gas then comes back, kinda sounds like a slow 2step...idk how to explain better....keep in mind when commentin my harness is sorta HACKED! so it has some plugs unplugged...can that be it? Lmk! Ask questions!
    Check your TPS
      Originally posted by turbohatch900 View Post
      Check your TPS
      -_- I feel retarded....I don't have one connected
        All Ur sensors need to b connected... then check it...
          Smh
            Smh
            x2
              Sounds like the iacv an the iat are pluged in backwards
              J-ROC TUNING
                Previous owner said it needs iac valve
                  ^^^I got IAC if u need 1.. I got a whole LS mani too.. LMK if nethin
                    i also have an IACV obd2 ls
                    203CARTEL_John$
                      they both
                      have the same plug
                      so do map and tps
                        Originally posted by 1320 View Post
                        they both
                        have the same plug
                        so do map and tps
                        I can't find the map!!
