Going threw problem: Need Answers!
  • Going threw problem: Need Answers!
    Okay am posting this thread for a friend. my friend car is starting to stall out while driving then after it stalls out, you can start it right up.Has no problem with starting up. The car idle fine sometimes, nothing rough, but we we're thinking it was probably the tpc or the crank position sensor,am not a mechanic or nothing so cant tell if its bad but this the info we got from other people, their is a check engine lights but its bcus of the sec o2 sensor. Need some Advice or HELP! & the car is a bseries VTEC EK
    98Ex DD EJ8 ROADRUNNER
    & we ended up doing a diagnost test and only ran up the o2 sensor, so idk..
      Just need some advice before he start spending money for no reason,went on google, a guy said could be the fuel pump, one guy said could be the dizzy, sooo need some advice!! come on CTVTEC
        ttttttttt
          It could be a wire problem some thing cutting out did you Eva try a diffrent ecu
            ^ Nope never got a chance! Ima try my friend ecu and see
              change tha oz senser and run a cat test on it when willbit stall out as soon as u hit tha throttle?
                i dont think its the cat cause the whole exhaust system is new and so is the cat.. and the o2 sensor is good, we;ll the primary one is, and yea sometimes when i hit the throttle, like i put $20 gas in my tank and i drove it today and didnt do it, but idk..
                  bumppp
                    ^ Thanks bro....
