What's CEL reading?
Misfire?.. NEW PROBLEM
still throwing same code #14 which is IACV and i pulled the injectors and one is missing the little screen and 2 look different than the other 2 is that supposed to be that way? the bottom near the nozzle 2 are bulkierR.I.P Nick Haines
203CARTEL_John$
Originally posted by game2o3 View Postyooo, u sure its not electrical?PinoyDelSol
im thinking its the injectors since one looks hacked the f up! i cleaned them up threw them back in the problem isnt as bad as it was yesturday so im gonna order a new fuel filter and put that in and see what happens and see if i can find some cheap injectors for now.R.I.P Nick Haines
203CARTEL_John$
I still think you should hit me up! So I can sit on your driveway and smoke boogies while I see you put in work like last time! (phats fa5)PinoyDelSol
lmao!.... im done for the day car runs ok at idle drove it and doesn't stutter like it was yesterday. yo i got a 09-10 foglight oem honda only one tho bracket is broken but the lens is good and still has bulb $20 if you need it.R.I.P Nick Haines
203CARTEL_John$
Originally posted by KILLERFERIO413 View PostSound like the module inside the dizzy is bad.... My car was acting the same way.. Shit would back fire and act up bad between 1-4000 rpm untill i changed it.... Get a new dizzy or module and u should be good...R.I.P Nick Haines
203CARTEL_John$
my 98 gsr was doing the same thing, look at the ground wires that go to the thermostat housing if they loose connection they the throw a random misfire code and case the motor to bog like its gonna stall then it takes off. the way i found it was i had the car running and i pushed on the intake pipe it moved the harness and it stalled i just kept moving the wire harness around till i found it. hope this helps GL
