b series idle info?
  • b series idle info?
    my b-swap idles around 400-700 rpm but no over heating or when i hit the gas revs right up sound like it shut off but idles at the same spot again...any ideas?
    and when i hold the gas around 1000-1500 sounds like i have a two step...ideas?
    wanna know what they can be
    bump if you view need the help asap!!!
        firing order?
          misfire? try adjusting your idle via the screw on the tb
          has it always done this or is it a new swap
          S3-R
          Stage3-Racing
            Bad tps
              either off timin by a lil or... iac if u rev it lik that n it sounds lik a 2step...
