B18B1 swap into 2000 EJ8 car starts every now and then, when it is running i try to give it gas it boggs and backfires all the way up to 3000 rpm then shuts off. already replaced dizzy,wires,plugs,headgasket(full rebuild),map sensor,tps checked timing a million times..... im using 0bd2b to obd1 jumper harness with pr4 someone help me plzzzzzzzzzzzzzzz :(
Help!!!!
