How to flush a bseries motor.
  • #16
    Originally posted by *Kung Fu panda* View Post
    Sea foam will work but the car will smoke for a While after that...
    Yea then seafoam it, let it run for a while untill the smoking calms n ur good....
    • #17
      Originally posted by ej1 sleeper View Post
      hmmm i seee. so i guess we can drain all the oil out in the motor then put sum oil n seafoam n let it clean out?
      i dont know if your supposed to drain all the oil. Your supposed to let the sea foam go in through a vacuum hose/line or something like that.
      01 RSTi RHD Project Car // 98 EJ205 GF8 Daily
      JDMVIP.com Moderator
      • #18
        i'd do like 2 oil changes and sea foam.
        • #19
          X2
          • #20
            put about a third of a can of sea foam through the brake booster vacume line but do it SLOWLY FOLLOW DIRECTIONS YOU FIND ONLINE!!!! will clean that head out like no other. also put some in the oil, and gas if you really want to just clean EVERYTHING, i have seafoamed a couple cars and it always makes them run smoother and better in general. just be carefull going through the vacume line your sapouse to let teh car die at a certain point or something (havnt done it in a year or so), just youtube it and watch it a couple times then do it. i always use the brake booster as the vacume line to suck it through.
            VTEC is just way to much fun
            • #21
              smoke usually last about 10-15 depending how much build up is in there, i wouldnt suggest driving it at all on a road untill the smoke thins, iv had my whole driveway in a smoke cloud before from doing it lol
              • #22
                x3
                Hidin' out
