big problem
  • big problem
    can i use a ls crank position sensor on a gsr block if i cant wat can i use please help
    How does your car run with a bad crank and tdc sensor just wondering I am having problems also I have a h22 with check engine p1361 and car is surging at 3000 rpms and when you give it gas boggs it not driveable just wondering thx
    IF I WANTED Z3 FENDERS I WOULD BE ROCKIN A BMW
      sensor should be the same
        bumpp for B series probs!! Help this man!!
          Sensors should be the same, although I am not sure because the LS crank has more stroke no? BEST THING go to AUTO PARTS STORE and ask for both part numbers!!!! It works every time! :)
