misfire/sputter issue
  • misfire/sputter issue
    basically at 3000rpm or less under load car sputters if i hit the gas 1/2 and up throttle.but drive less then 1/2 throttle and cruising a 3000 or less rpm it sputters and kinda jerks the car slightly. now m thinking icm but i cant find any resistance specs for the icm. or even the coil. anyone help me out
    RIP Nick Haines
    wut car is this for and if you need a test dizzy lmk i'll lend you one
    860 member #18
    puerto roc #1
    Cosa nostra
    ASAPRadio.net
      its for a 97 integra gs....and i dont like borrowing from someone cuz my da had kinda the same problem but kept blowing out icms and if its the same issue i dont wanna ruin someone elses ************...i just want resistance and voltage specs so i can test the components in my dizzy...basically plugs wires cap and rotor are all brand new and inspected all those and i dont see any visual issues with any of it..
      RIP Nick Haines
        yea u def. need a new dizzy ....
        " Mr. Tough Guy "
          maybe ur dizzy is advanced a lil cuz i had the same problem
          white people suck
            i have the same problem at 2000 rpm's it sputters or misfires... i gotta check that out im thinkin its my dizzy...
            TURBO 2001 IS300
              nah does it at all angles...tried retarding it, advancing, right now its at factory set...still does it...
              it prolly is ur distributor, but yours is doing the exact opposite of mine...mine clears up past 3000
              RIP Nick Haines
                change the whole dizzzy....
                " Mr. Tough Guy "
                  gimme a dizzy then :D
                  RIP Nick Haines
                    lol u hit...
                    " Mr. Tough Guy "
                      lol u hit...
                      ur a good help critooo :D
                      RIP Nick Haines
                        happened to me change the dizzy and u should b good
                        2o3 crew member #30
                        93 captiva DA9
                        GHK all day #7
                        RIP NHswaps13203
                          if i had 1 men i would hook u up....
                          " Mr. Tough Guy "
                            I have seen cracked rotors cause those exact problems. Sometimes the rotor will crack internally, & short out against the Dizzy Shaft under high loads. What kind of rotor you have? The Auto Zone & Advanced rotors are suspect. OEM Honda parts FTW. Might not be your problem, just thought I would shed some light.
                            You can swap any D-series Distributer in, just for a tester, you'll probably only be able to get 1 dizzy bolt on though, which is fine for just a tester.
                              find me a dizzy son
                              H23VTECLUDE I have seen cracked rotors cause those exact problems. Sometimes the rotor will crack internally, & short out against the Dizzy Shaft under high loads. What kind of rotor you have? The Auto Zone & Advanced rotors are suspect. OEM Honda parts FTW. Might not be your problem, just thought I would shed some light.
                              ill look into that
                              RIP Nick Haines
