Going to run Ctr pistons what kinda rigs should I use ?
Someone HELP
Make sure your piston ring end gaps are correct. If you have the stock 81mm bore your top compression ring should be gapped to 0.019" and your second compression ring should be gapped to 0.023" as for the oil rings, just check to make sure they're not gapped smaller than 0.015".Hidin' out
If you honed the cylinders you have to account for the extra material taken off of the cylinder wall. Get a micrometer and measure the cylinder bore. Got to your local machine shop and give them the measurements of the piston and the cylinder wall and they will set you up with the best set of pistons. Do not gap them too much becuase you WILL get serious blow by.RIP NHSWAPS13203
