Help.......
  • Help.......
    I have a 93 bubble wit a 94 ls n Gsr tranny. And for some reason it's waiting alot of gas I tried tune up everything. After I switched the fuel filter is wasting even more gas. There's no leaks of gas anywhere . What could it b?
    I'll b surprise if I get 10 miles to the gallon
    You have a problem if you're getting 10 mpg.
      10 mpg, damn. stock injectors?
        precision 1000cc injectors. duty cycle 100%. fuel pressure 80psi.
          Like my old ls I got 12 mpg with a blown head gasket needed a valve adjustment so bad but hey gl I just sold my junk that's how I got rid of my problem
            Stock everything but pipping n headers n on top of that I do delivery so I b putting like 30-40 daily
              that sux bro, any check engine light??
                Np check engine it barely smokes so I don't think is a head gasket
                  what ecu you running? do you have a stock fuel pressure regulator? are you running an o2 sensor?
                    i'm havin the same problem on my singlecam, just not as bad as 10 mpg, but gl with that bro
                      I have a p75 ecu n yes I do have a o2. It has everything it used to waist some what a decent amount of gas but Lil by little it got Worce n now is just ridicules
                        maybe your sending unit is bad.
                          And what n were is the sending unit
