I bought a b16 head for my b18 non vtec. Everything is all put together except the coolant lines. The head came with an intake mainifold that is p73. There is an extra coolant line on the mainifold can i bypass this some how or do I need a different intake mani?I thought it was the stock manifold when I was putting it on so I didnt think I would run into this prob. Do I need a type r throttle body?
Intake mani help
u should literally delete all small coolant lines to begin with. The throttle body ones and iac ones. Think about it y would u want hot coolant going threw your tb where cold air is suppose to be coming in..... a wise man once told me this. Done it to all my cars, zero problems.My transmission's went 9's
http://youtu.be/z2PHemIp_Tg
Originally posted by cts mr.niceguy View Postu should literally delete all small coolant lines to begin with. The throttle body ones and iac ones. Think about it y would u want hot coolant going threw your tb where cold air is suppose to be coming in..... a wise man once told me this. Done it to all my cars, zero problems.'97 Mitsubishi Galant - Junked
'93 EG Si Hatch - DD Project
My eclipse has the same setup run and I used to wonder why all this crap was needed. Why cant they make these engine bays simple for tuners so we save time and stop trying to figure out how to make their cars better lol.94 eg 4dr aka baby pusher
run the intake manifold small outlit to the outlit on the cooling tube that connects the thermastate to the waterpump( its a small nipple) u may have one more on the waterneck on the head( if its a b16) just cap that off! youll then have no tb lines or iac lines, presto your done.My transmission's went 9's
Originally posted by cts mr.niceguy View Postu should literally delete all small coolant lines to begin with. The throttle body ones and iac ones. Think about it y would u want hot coolant going threw your tb where cold air is suppose to be coming in..... a wise man once told me this. Done it to all my cars, zero problems.D and G auto member #5
indeed sir indeedMy transmission's went 9's
