Not sure if I get B16 head studs or b18.
What head studs should I run for lsvtec
Originally posted by Can~i~bus View Post^^nope
All Motor / Naturally Aspirated - How to build a reliable lsvtec/b20vtec - I put this guide together because I'm tired of seeing the SAME threads over and over of simple questions that can be answered in one simple post like this one. This thread is designed to be an end-all, tell-all type thread. Please keep in mind...
if you want more lmk!
oh and i had lsvtec b16a head ls block gsr studs.. if you knew anything you would know that b16 studs are shorter and ls has 2 long studs in the cneter of the head. hence why you need gsr kthanksbi
heres crvtecs
208-4306 B20B, w/B16A head
Head Stud Kit with 12-Point Nuts and Undercut Threads
so cause you got it its the only right way? fuck outta here
hence you'll b okLast edited by Can~i~bus; 02-15-2011, 01:09 PM.
