will this sensor cause the car to not start up? or start up n shut off once i try to rev the car? cuz these are the problems im having with my integra any suggestions on what to check?...thanks
IACV question
it wont cause it not to start. more details thouMy transmission's went 9's
http://youtu.be/z2PHemIp_Tg
Originally posted by coupe4showill this sensor cause the car to not start up? or start up n shut off once i try to rev the car? cuz these are the problems im having with my integra any suggestions on what to check?...thanks
ok so the car startted up fine then one day i went to start it n it didnt wanna start i changed the fuel pump n it reads 35-40 psi everything is plugged upi changed the map sensor n i changed the intake manifold n tb gasket thinking it was vaccum...if i spray the inside of the intake with starting fluid the car turns on after a couple cranks and runs perfect lol weirdest shit i was guessing the iacv or a vaccum leak somewhere but idkWorking in Silence 203
Originally posted by 203CARTEL_NeiL View Postlmaooo i was serious nigga i did that before had left one of the plugs lose it still started just didnt stay on
neil u know i been checking dis problem for two months...im sure i wulda noticed the ecu unplugged lol i changed out the ecu multiple times to see if it was dat but no luck still n its gona be resprayed dis week but i want it running before i send it outWorking in Silence 203
