I was draining the mtf and i've caught metal pieces and shaving with my blox magnetic drain plug. When i drained the mtf i didn't see any brass shavings. So i took pics and want you guys to see where it's coming from. It appears to be 1/2 second synchro sleeve, correct me if I'm wrong. 2nd gear was hard going into.
Pieces of metal from my b series transmission
Originally posted by BB DC294 NHCT View Posta good 25-50 dollars is worth the extra care.R.I.P Nick aka NHSwaps
ummm y get the magnet? there's 2 factory ones already in casing. and those look more soild gear pieces, but hard to tell from pic. I just sold a trans tonight that i did that had a magnet plug and i thru it in the trash, replaced it with a stock one.My transmission's went 9's
http://youtu.be/z2PHemIp_Tg
the more i look it may be teeth of the 1/2 slider .... the teeth for the reverse idle.My transmission's went 9's
got some extra parts lmkMy transmission's went 9's
yeah, those look like chips of gears, not synchro material. correct me if i'm wrong, but synchro material would be brass, that looks like pieces of hardened steel- aka teeth. does the car make any clicking noise in any gear?
