B20b issues, need help asap!!!
  • B20b issues, need help asap!!!
    just did my b20 swap, started it and the engine is running off cylinder 4,3,2 cylinder 1 is misfireing. changed spark plugs, wires, distributor cap and rotor. checked the fuel injectors and it still is running like pure shit. it is getting fuel put not fireing. this is in my ek, i used the stock harness, used a jumper harness to run obd1 and i am using a b20 computer. some said it is the headgasket cause he had the same problem. just wanna see what other people would say about this issue. thanks need help asap
    bump, bump, bump
      did you do a compression or leakdown test?
        X2 nd maybe it could be the ecu mine ran like shit until I switch em
          the b20 is know to burn valves i have done countless cylinder head rebuilds for crv's because of a skip no one can find and people were quoted a new motor pirce and it is just a simple valve replacment. do a compression test on the motor.
            valve adjustment
            (860) and beyond
            #DavesTuning 8608050968
              did a compression test. all cylinders are at 180-185 there all excatly the same. i dont understand what the fuck is going on. i order the engine from tiger jap.
                injector
                (860) and beyond
                  when i had the headgasket issue my compression was perfect to thats why i didnt think it was headgasket at first lol
                  !!!!!ThE GoOd DiE YoUnG!!!!!
                    Originally posted by daveedd357 View Post
                    injector
                    sup dave
                      changed them to the other b series injectors i had on my ls
                        need help. timing is good. valves are good. engine was just shipped to me and dropped in i dont know or inderstand what else the problem could be with this. i guess i should just go with changing the headgasket and see what happens
                          if anyone has any other trouble shooting ideas, please lmk
                            check engine??
                              get a pulse tester and put it on your number one injector and see if it the the light flashes if it doesnt its your wiring if it does check the injector. if every thing checks out there id do a leak down test before bothering with head gasket. dont keep swapping parts cuz your just wasting boat loads of money just saying
