well i checked the timing and it was on both cams were str8 up and both little slices on cams were lined up perfect and the single white line on damper lined up with the maker on the cover! so its all good! does it matter that i have rebuilt this dizzy once before??? because my needle isnt jumping and it turns on just fine!
Please Someone Help Me!!!!!! B Series In Side!!!
put the engine on TDC (top dead center) instead of using the front markings of the cam gears, check the back of the cam gears, there are markings back there for better timming points. for some apprent reason, on GSR, those stupid markings in front never work too well. Def check out the valve lashing as well. I had the same issue with my itr cams, until I redid the timing about 8 times... and hopefully your SUPER fuel feeding didnt wash out your rings, but thats besides the point. just make sure timing is dead on. thats what will old it back a whole lot. especially at HIGH RPMs.~StayinFRESHSINCE1982~SPUNKY MONKEY CREW MEMBER #1203 CREW MEMBER #33
Originally posted by Rla_Eg6 View Postwell i checked the timing and it was on both cams were str8 up and both little slices on cams were lined up perfect and the single white line on damper lined up with the maker on the cover! so its all good! does it matter that i have rebuilt this dizzy once before??? because my needle isnt jumping and it turns on just fine!Kris
im gonna try to do a compression test tommorow cars not smoking as of now and oil is the same as when i had the stock cams so im sure the rings are fine! my pcv is new but im gonna double check everything i can just to make sure everythings on point URGH my head hurts also start up i fine right now starts up quick i think better right now lol
Did your crank move at all?
Set the crank to TDC (number 1 piston should be all the way up top, or you can look at the crank pulley...either way)...then line up the cam gear marks facing each other in the middle to set the cams at TDC I believe (check Haynes manual).
Then you might have to adjust your ignition timing with a timing light and moving your distributor.Last edited by EM1_Chris; 02-12-2008, 09:28 PM.2000 FBP EM1
