Please Someone Help Me!!!!!! B Series In Side!!!
  • Please Someone Help Me!!!!!! B Series In Side!!!
    guys i have a problem not sure of what it is!!! so you guys know i dyno's it! ok well i got a lil too happy and decided to throw type r cams in. at first car seemed to be running fine well at first bad so i set fuel pressure down! on the street ran hard on highway sosososo sluggish! so i decided to take it back apart in the garage i found timing was off! so i put the car in timing set the fuel at 48lbs with the vaccumm off now when i bring the rpms up slowly when vtec engages all is does is sputter HARD! and when i punch the throttle down itll open up but keeps puttering and the car feels held back like crazy!!!! please any help will be appreciated
    things i was thinking fuel pressure still to high or low! misfiring maybe bad plugs!!! can it possibly still be off timing! damn i got a headache lol
    My work: Flikr.
    Andres Valentin Photography
    timing dude. def
      but i did redo it putting the fucking allen keys in the holes in the cams and shit im stumbled
      My work: Flikr.
        try setting your fuel pressure back to stock and see what happens..
        ...44PSI
          ok im gonna do that now 44 psi! brb in a few!
          My work: Flikr.
            good luck tito..get that shit running hard...
            cripple member : P
              i would check and make sure the o ring on the camcap is in and didnt fall out the one in the center.
              337_runner
              HIGH OUTPUT CREW #1
                Check the valve lash. very important. I like to hear my valves at work.
                (860) and beyond
                #DavesTuning 8608050968
                  whats the update tito is she running yet
                    bump for tito's whip....is it all good nigga?
                    cripple member : P
                      ok heres the SIt. i turned my fuel pressure down to about 44 or 45psi now i let the rpm come up slowly to vtec and it engages pretty clean! but now if i stomp on it what it does is it feels held back and sputters! i pulled my plugs and they looked like dark greyish idk if i fouled them out from what my fuel pressure was high! omg man im stressed please help! and i never checked for that o ring what can it cause if its not in there!
                      My work: Flikr.
                        It may be running lean. Call when you have the time. David
                        (860) and beyond
                          iight calling!
                          My work: Flikr.
                            I would check my timing. Make sure cam timing is good as well as ignition timing.
                            Also is it throwing any codes? Any CEL???
                            Sounds like when my dizzy went bad
                              My timing was never right when I aligned the holes in the cams with the caps.
                              IIRC, doing that puts both camgears off by a tooth. Try turning both cams counter-clockwise by a tooth.
                              Kris
