Help...
  • Help...
    so im driving my bubble today and while im driving it started to choke and keeps doing it picks up fine then it chokes wtf is it?...95 civic bub gsr
    Could be a lot of things. My guess would be your fuel pump is on it's way out.
      Sounds like your cat is clogged to me.
        That too. Shit. Could be a lot of shit from the description.
          Does it bog at all getting up to speed before it chokes or does it bog (choke) once its at a higher RPM?
          Start with a fuel pump and a compression test.
          Check the cat, timing, if the wiring is hacked check that maybe someones foot hit the ecu wiring and it got messed up.
          There are so many things.
          Dizzy, sucked up water, partially clogged injector.
          Start small.
          Cat, comp test, Fuel pump.
          RIP NHSWAPS13203
            i mean it drives then it chokes for a bit then it picks up and goes then itll do it again..sorry dont have much more info but thatshat its doing
              Then i'd think clogged cat.
                Start small.
                It starts to bog around 4000 rpm or sometimes even lower but thanks for the help ill check all that now
                  Ill check...thanks
