B20/vtec or ls/vtec?? Need opinions lets see them
lsv or b20v
neither. if honda wanted them to have vtec they would have, the cranks arent designed to rev higher then 7.2k sooner or later it will break built or not. yes people do it ye they have lasted a while but the money you spend on that doing it right u could have a nice gsr which has vtec and is a strong motor
Originally posted by mark11017 View Postneither. if honda wanted them to have vtec they would have, the cranks arent designed to rev higher then 7.2k sooner or later it will break built or not. yes people do it ye they have lasted a while but the money you spend on that doing it right u could have a nice gsr which has vtec and is a strong motor94 eg 4dr aka baby pusher
There are no major differences between a ls block and a b20 except the bore size. Me and my friends have had lsvtec set ups and b20vtec reving 9+ on stock sleeves all day. Forced induction is another story you have to sleeve them for them to last. B20s do have smaller cyclinder wallS then a ls that's why ppl say the are weak but it's no big deal unless you are planing to run mad boost or nitrous. I had my b20 block bored out to 85mm no problem on a allmotor set on stock sleeves.
That is someones personal opinion on these setups! He broke it down very well but if you never had a b20vtec or lsvtec you canT listen to that because it's not factual. You have put them together right if you don't your gonna have problems.
Originally posted by allmotork24 View PostThat is someones personal opinion on these setups! He broke it down very well but if you never had a b20vtec or lsvtec you canT listen to that because it's not factual. You have put them together right if you don't your gonna have problems.
