B16a2 issues
  • B16a2 issues
    Hey ctv im tired of freezing my ass off in my garage and need some help.
    I have a 00 civic si that doesnt start but cranks slowly and diff.
    Ive checked the battery, all connections, it has spark, its getting fuel, i checked the timing at the crank, cams, dizzy...all good at TDC. I scanned it for a code and it brought up a p0117-engine coolant temperature circuit low input. cant seem to figure this out. help me out guys. oh car wasnt running when i got it.
    MOST DOPE CREW
    MOST DOPE CREW
      sand down all your grounds and reconnect them also check you battery fuse under the hood
        he obviously scanned it,so i doubt its his ground
        just saying...0.02
          hmm ill have to check the fuse tnx
          MOST DOPE CREW
            coolant sensor on the side of the head.. if its unplugged or shorted the car will not start. it sounds rediculas but ive seen it before. that MAY be the problem but idk
              ok well i just replaced it with a new one today but couldnt try to start cuz my batt was dead but im gonna try it soon and if nothing im gonna check the wiring to make sure there are no shorts. thanks.
              MOST DOPE CREW
                did you take the distributor cap off and make sure when the motor is in TDC that the rotor is pointing at cyl #1 on the cap? sometimes they can be 180 out and be pointing at cyl #4 and cause no start. which would have spark fuel and sound good but not start.
                  check your main fuse? or distributor or sparkplug wires are in the right order
