GSR issues...
  • GSR issues...
    yea so i recently did the head on my gsr and now it doesnt start. it turns over quick, sounds good, like it wants to start real bad. but it wont. dizzy is lined up, no leaks anywhere, its torqued down proper, no unusual smoke, new plugs, its gettin fuel/spark.... idk whats goin on. i aint no mechanic tho.. any ideas?? i (DONT) wanna say it could be piston/rings... but im still skeptical sayin that. tops of my pistons looked fine, as did my cylinder walls..
    Timing is off check it, make sure the cam marks are lined up and that the pulley is lined up with timing mark on the cover
      either your firing order is off or your timing is off.
        gotta b timing...
          Where u from?
          J-ROC TUNING
            must be timing then.. I HOPE! even tho the arrows line up for TDC. unless she wasnt top dead...i got a light ill check it once im back at the crib. spaced on that. its def not the firing order.
              Originally posted by Jroc860 View Post
              Where u from?
              hartford area....why?
                i aint no mech but the only thing i can think of is your timming
                  Well make sure the cam gear marks align, I bet it's off a tooth which in some case it won't start
                    o yea good looks on some quick advice fellas...
                      this could be possible. it was my first time doing a head on my own. i think i was worrying too much bout how it lined up as i had the belt on/off at least 5x lol. im pretty sure it looked off a tooth either way i had it.. well see.
                      bump for antique timing lights
                        Cuz if u need help i might be able to swing thru
                        J-ROC TUNING
                          timingggggggggg
                          Follow me @bolacan413
                          Follow the build @k_insight
                            word yea i mite take u up on that. u could wire tuck? im thinkin im bout to start a tuck once the weather gets spring status. ill pm u
                              Originally posted by jealous1shateric View Post
                              timingggggggggg
                              thats what everyones sayin. imma check it asap.
