ls/v question
  • ls/v question
    Ok here's the scoop
    my boy has a ls/v
    b16 head ctr pistons
    thing runs like a single
    timing is correct
    just need some insight on what can be wrong.
    im tryna get my hand on a compression tester
    lmk
    Follow me @bolacan413
    Follow the build @k_insight
    What ecu is he running?
      i got a fully built b20v and its runny like shit cuz it needs to be tunned i got an ecu from my last built so i can brak the motor in but deff get it tunned
      E.S.T MOTORSPORTS
      203-528-0971
      B20V BIULT BY TurboManny
        we have tried my p28 with chip and a stock p28 same thing i don't think its an ecu issue at this point
          well we got stock cams and what not so i dont think its ecu
            i tried g/l with the car
            E.S.T MOTORSPORTS
            203-528-0971
              whats ignition timing set at
                Burim thats the worst thing to do..... Rick It still could b e a tuning issue. CTR pistons on a ls/vtec should not even see a stock or incorrectly mapped ecu. It has way too much compresson for that. Also, try to find more agressive cams too.
                (860) and beyond
                #DavesTuning 8608050968
                  get a nice set of cams and tune it.
                    http://www.ff-squad.com/technet/cr-calculator.htm way to high for a stock ecu. At least try a type r or gsr ecu and see how it runs.
                    97 Boosted Hatch my toy
                      the p28 was tuned by dave with a similar setup idk at this point
                        yea all these comp calc all say diff things so idk right now
                          if you have a header, and intake manifold and 2 1/4 exhaust then id try checkin the compression to eliminate that as a problem. if not try a new tune. if that dooesnt work i have no idea. just make sure you've got good compression and i/h/e to help that flow.
                            similar don't mean that it is right
                            (860) and beyond
                              Hmmm... could be as simple as one of your spark plugs connected correctly. If not that then definitely it's a tuning problem.
