engine tunning
  • engine tunning
    looking to get a s300 programed and my egine tunned looking for the best trustworthy let me know will be a plus if they come to me n ot sure if my car will even run
    Dave will be the man you need to talk to on there
      tried dave wont give me an answer and im trying to find someone who would be willing to come to me ive put alot of money into my car cant afford to have it stolen
        is it fully built? if not dave. if it is built and worth a really good tune make an appointment with yosolo. if you're willing to drive/trailor the car too evans tuning or nrg tech isnt a bad idea.
          Wow well I would trust Dave for sure only other place I would trust is nrg tech but they are in long island
            the motor is fully built but have not had it running yet so im not sure if the head gasket will leak or if the build was bad i just d ont know about anything so to trailor it some where may not be a good idea just in case the motor is no good northeast built the motor thats why i want some one to come to me so if i have to troubleshoot something i got tools and what not
              Well if your worried about the motor having leaks ect. first thing you should do is mechanical checks. start of with a leak down test, you can find a leak-down tester at your local harbor freight. Next step would be a compression and balance test. make sure all the cylinders are with in 10% of each other. Also make sure to perform these test dry then wet for best results and diagnosis. As for making sure the coolant system has no leaks you will need to use a coolant pressure tester. All these tools can be found at harborfreight for a fair price.
              http://www.facebook.com/?ref=logo#!/...582409882&ap=1
                what happened? ya bought a car, someone had a swap in it and the work was done at ne machine? so ya wanna tune it or theres something wrong w it?
                  bump for sqm knowing his shit
                  Follow me @bolacan413
                  Follow the build @k_insight
                    If you got bread just trailor it to MIller I got his cell number if you serious just pm me and I'll hit him up for you.. But MIller is pricey so come correct or leave ya shit at home.. I would honestly have Dave come thru and check ya shit out and fix it or hit up my nigga Danny aka singleslam and have it brought to there shop and they can fix it..
                    R.I.P Nick aka NHSwaps
                      203-534-9011 we are a hondata dealer and we also have a dyno we can tune ur car .. call or text if serious we are on the hondata website
                      D and G auto member #5
                        Dave or yosolo
                        Back-Yard-Boyz
                        PimPBays
                        Nyce1s.com
                          no i had the motor built i just need it tunned i need the tps sensor programmed is what ive been told i took a 70mm TB and put the stock TPS on it so when i touch the throttle it dies out plus i got a brand new s300 im trying to us i guess its a dead computer cause no programming has been done
                            Call me at the shop 203. 330 0872. Ihave a dynapack. I also pick up and drop off cars I have my own truck and enclosed trailer.
                            Crx 18 psi 441-308
                            crx. 20 psi 400-270 DYNAPACK
