fuck that rywire sucks i had it in my EF. to much money. just convert it
and theres a little metal thing you can press out of your hubs to make the axles slide right into your stock spindles.
I have rywire in three of my cars and used them in ten other no prob better then half add vtec contolers and hacked up harness plug and play is best money spend and tunner friendly
So u telling me the stock hf harnes can be used.. Just wire vtec.. All plugs match? Wow.. Didnt knoe im not a b series guy.. I fux with h and f series...ok wha ecu do i use...Is a b16 head good for that ls vtec conversion... i thought b18 heads were better to do ls vtec
gsr heads raise the compression because the combustion chambers are small. you'll go faster but i like b16 heads cuz they're the same casting as a type r.
