b20vtec no start
  • b20vtec no start
    whats goin on ctvtec i got a b20vtec and it wont start...i got spark and fuel...it pops and back fires once in a while...any suggestions plz feel free 2 let me know..thanks..
    check the spark plug wires make sure you connect them right
      Do u have aftermarket injecots if so how big are they u might be flooding the spark plugs.. Or if u have a regulator turn it down to 32-40 psi check timing make sure its not off a tooth or 2
      D and G auto member #5
        sounds like firing order is off
        mechanical timing could also be off a degree or 2 as stated below. start with firing order then check timing and make adjustments if needed
          Check timing
          J-ROC TUNING
            If you have spark and fuel it must be the ECU or firing order.
            No CEL?
            Apply it!
              check the timeing , cause i had this civic that was starting with back fires but it turning on , so i took off the head and it was off timing so i say check timeing
                ok so i checked timing and it was a lil off fixed it and still nothin...it was making a blump sound...its turnin over good..idk..its probally something stupid..
                  ok well i checked the timing it was a lil off so i adjusted it..still no fire...wen crankin over it was makin a bluomp sound..idk wut else it could be...the ecu worked with my last swap and my old car b4 this 1..
                    sell it to me...
                      naww got alot invested into and if i sell if i wont get cclose 2 some money bak ..i juast wanna figure it out...
                        u need a macanic if u need on pm me
                          it the head build ??
                          :cool:
                            meaning springs and valves and retainers
                            :cool:
                              the head went on the way i bought it from est motorsports..never touch anything on the head...there good guys there..but idk i hope nothin wrong with it...
