Not sure if my Gsr is reving to proper rpm! + CEL is onPlease help
  • Not sure if my Gsr is reving to proper rpm! + CEL is onPlease help
    I have a Gsr bubble. It's a dx and had the stock gauge cluster in it. No tach. So I bought one from a junk yard with a tach but it was out of an automatic 4 door. Anyways... I hooked it up and it works fine (so I believe). When I redline my gears to the max, the tach is reading only 7600 rpms. Is that right? Or is my tach not reading proper. I have a 95 usdm Gsr motor with a 99 usdm civic Si tranny. Redlining 3rd gear, I'm doing about 85 86 mph and my tach is at about 7500 7600 rpms. Is my motor really reving higher? I know the Si tranny has really short gears but does 85 mph redlining 3rd sound right with a Gsr motor and a Si trans? Im pretty sure the computer is stock to the motor also. Some one please help. I wanna know if I can get more out of this set up. Also. I have a check engine light on. Anyone know where I can get it scanned really cheap. I need to know asap. Emissions... Please answer all my questions. Thanx :)
    first of all, a automatic one isnt read fine in the car, thats prolly why youre throwing a code. get a p28 out of a 5spd civic ex. then your car should run alot better.
    ~StayinFRESHSINCE1982~
    SPUNKY MONKEY CREW MEMBER #1
    203 CREW MEMBER #33
      bump, cause i have my cousins stock p28 for sale, if you wanna buy it lmk
        Wtf I always herd auto clusters r fine nd aslong as u got a obd1 p72 ur fine u don't need a p28 nd for the check engine just jump the harness with a wire or something nd learn the codes for the flash bro lol nd the reason why u probly raving out at like 7600 rpm is cause u got a p28
          idk im at 7000 at 85 mph
            what ecu are u useing ... also a auto cluster isnt going to fuk with u there all the same except the auto has the p.r.n.d.1. on it
            D and G auto member #5
              what kinda ecu u runnin. cause if its a virgin p28 ur always gonna rev that high bro.
              Down Since 09 ...
              Mugen Inspired DC5
                Yes Chang the ecu and that shit will run good that's a nice setup
                I STILL ROCK OEM WHEELS AND IM PROUD!
                  X2 like I said an auto cluster don't matter but yeah what kinda ecu
                    the c.e.l. code could b the reason it wont rev higher
                      oops i thought he said automatic ecu not tach! my bad
                      203 CREW MEMBER #33
                        def an ecu issue.......
                          my shit revved to 8800 when I had it. thanks to that chip, an a lil work.....
