fuel pump problem
  • fuel pump problem
    i have a 91 crx si and i drove down the street an a reallly hot day and i didnt let the car warm up or nething so i drove like right down the strett and when i shut it, it was stil cold so it shut down sort of hard.....so 10 minutes later i go to start it to go home and it wont start....so i listened for the fuel pump and its not turning on at all so i tried changing the main relay thinking maybe it warped because it was so hot and still the same problem.....so is the only thing left to check the fuel pump?.....and what models will fit in my crx correctly
    see what sucks is u do not have direct access to your pump, you have to drop your tank, cause if u had direct access to your pump u could just run direct power to it and see if it turns on......
      Fuel Pump
      I'll be Honest, I've never seen a Honda Fuel Pump Fail, I've Seen some Weak Ones where the Fuel pressure was low, But never seen 1 staright out fail. That's 7years in a Honda dealer & about 11 yrs of Honda Wrenchin. Did you put in a known good Main Relay? Has the Tank ever been Down & Tinkered with? I willing to bet, Main relay or wiring.
        yea thats true.....idkkkkk
          i had the car 5 years now and i never touched the tank....and yea the main relay i put in is mint.....is there nething besides the relay that could be causing the pump to not get power?....and i no u said u never seen 1 fail but would running the b16 on the stock crx pump like i been doing cause it to fail?
            Main Relay even if the one you just put in is mint it would have gone bad if its used brother. My buddy carries around liek 3 main relays and has to switch them out frequently and there all supposedly "MINT" lol
            Justin
            Send It !
            Stroked GSR Slugs & Sticks
            HONDATA, CROME PRO TUNING
            ECU Tuning, Socketing, Turbo kits, Motor swaps, Engine builds, Regular maint, CT, Low prices!
              no i mean the car died and then i swaped the main relay and it still didnt work so the main relay had no time to go bad since it has even ran in the car yet....unles your just saying it could be bad already....either way idk the cars a headache
                Join the club man these junks are nothign but headaches LOL but when they run good its like the best thing since sliced bread LOL. ive been battling overheating and just finally nipped it in the ass last night now the car is running normal temps with a big ol 14" fan
                Justin
                Send It !
                  lol i totally agreee i loveeeeee when m,y cars running and its funny you say thats because im battling over heating issues too
                    What chassis and setup? I battled the overheating and took every angle till the last two steps fixed my problem. Im sure i can help
                    Justin
                    Send It !
                      91 crx si with a b16a
                        stock b16 thats it and its overheating? hows the tstat. leakdown? rad condition
                        Justin
                        Send It !
                          radiators baswically new and i gotta replace the thermo and then check it....my main problem is my fan dont kick on so i ran it to a switch....but besides all that i still gotta get the car to start again lol
                            look at a wiring digram and find the fuel pump power wires and see if your getting power to them cause i know the pumps are barried on that car unlike the newer models. try a different ecu just to see if the fuel pump powers up too. make sure your grounds on your t-stat are tight and your tranny ground is on tight
                            Justin
                            Send It !
                              besides the main relay are there any other fuses that coulda blown causing the pump to not power on?
