Car Will Not Start!
  • Car Will Not Start!
    Ok boys and girls heres the deal...
    Car was running fine. Turned it off lastnight. Now wont start.
    Main relay does not click.
    Tried 3 differ main relays that are known to be good.
    No Spark/No fuel.
    Put power directly from battery to the main relay power nwire. Car starts and runs fine. But if I turn the car off and crank it again it will not start.
    If I take the power wire off and put it back on it turns on right away.
    Im clueless. Swapped engine harness, ecu, battery, checked all the fuses, swapped dizzy..
    Any ideas? It has headlight fluid, vtec fluid, muffler bearing all the bullshit so don't waste your time asking.
    check your ground? maybe when u take it off your shaking something just right
      bad ground?
        Grounds are fine. Im thinking ignition switch. But no one has it in stock.
          sounds like ur not getting any power too the main relay........so check ya wires it might have a break in it
            I know for a fact im not getting any power to the main relay.
              did u check for oil on the secondary dip stick? jk i know you said you checked fuses but double check ecu fuse in the bay, if im not mistaken ecu gives power to main relay
                yea i swapped the ecu fuse out just to make sure. Im gonna double check em all today. Shits driving me insane.
                  well your on the right track.. you know that the main relay is not getting power so trace back to the source and see what you find. if its obd2 im 98.6555% sure that ecu gives power to relay. and its a 15a fuse under hood first one all the way to left up top
                  then again if your feeding power directly to main relay and it starts then the ecu fuse would be fine. if anything trace wire and look for a break
                    Thats the plan Mark. Im gonna go check the ignition switch to see if it's sending power.
                      Check ur alarm if have one happen to me once
                        No alarm yet. Just got the car regi'd. Im gonna take a volt meter and see wtf is going on. Been working on this all night / today. Shits driving me crazy.
                          Not enough blinker fluid shuts the ecu down because of unsafe driving without blinkers. I'd check the levels...
                            ^ levels are filled to max with D0T 4.
                              prob the ignition
