reving help asappppp
  • #16
    you using the sensor on the fire wall or the im? that may be the problem too
    • #17
      Originally posted by NECTUNE203 View Post
      vac leak
      x2 check manifold to head bolts, and make sure the throttle is closing all the way and not stuck at a certain position.
      • #18
        indeed
        My transmission's went 9's
        http://youtu.be/z2PHemIp_Tg
        • #19
          stratfoprd shelton area cant seem to fix this man lol
          • #20
            holy wang ill far away
            • #21
              could it be something with the gas like injectors or fuel pump maybe your tb cable
              • #22
                Fixed it some but still revving high and still reading bad sencors anyone have a throttle body with the sencors attached so I can see if it's anything else help please will give u parts haha I have stuff laying around valve covers and intake manifolds lol
                • #23
                  ^^^ I got a MAP sensor. LMK
                  • #24
                    ttt someone wanna help me out with letting me barrow a throttle body with sencors so i can rule it out
                    • #25
                      Did u set your tps you can't just trow a new tps in without adjusting it.
                      S3-R
                      Stage3-Racing
                      • #26
                        i did tryto set it and calirate it but all i could get was a reading of 5v everytime idk why sucksss
                        • #27
                          If this anything lile what happened to me: Good luck! I would strongly encourage you to swap out the FITV with one from another car and see if that works!
                          With my car, out of the blue, the car reved by itself while idling. And as time went by, on start up (cold engine) it would rev to 3, 4 or 5k some times) until it got hot, and then idle went slowly down some, but higher than stock... After much tinkering on tps, IACV and other sensors, unbolted my FITV valve and found out it was broke (when i shook it, it rattled. It should not!). Bought a used one, cleaned it, tightened it, and voila! Idle reving really high fixed!! FITV FTMFW!
                          if that' aint it, good luck!!
                          92 EH2 - Red Daily beater
                          • #28
                            What's the fitv never heard of that
                            • #29
                              FITV=fast idle terhmo valve. It basically works with teh Iacv to regulate ur idle etc...
                              google is ur friend!
                              Acura Integra - *** How-To*** Clean Your FITV aka Fast Idle Thermo Valve - First things first, you have to determine if your FITV needs cleaning. Now if you?ve never done it before it probably does unless you bought a complete new one. Reasons why you should take it apart and cleaning it: -High idle before your car...
                              If this is ur issue, and urs is not broken, then it's a quick fix and easy!
                              good luck & keep us posted
                              • #30
                                actrully that was going to be my next step to clean that part i wasent sure if i should of not once i get outta work ima try it thanks man
