reving help asappppp
  • reving help asappppp
    car says need tps map changed them 3 damn times car is stilllll reving high as hell and reading bad someone help me if u think it might be something else im bout to loose it cant afford all these sensers im going nutts someone pleaseeee
    you sure you got them plugged in right and not plugged in backwards?
      where u located im sure i can fix that shit sounds like u havin the same issue i had with my car
        im located in stratford at work right now im going nutts right now and their plugged in right so idk fuckkk lol
          someone anyone help me
            You prob need to calibrate your tps
            S3-R
            Stage3-Racing
              how do i do thatt
                vac leak
                  here just follow this...
                  in this thread i will be showing you exactly how to adjust your tps sensor. the vehicle is a 2001 acura integra gsr the sensor i have is a yonaka sensor from japan i had installed it the other day and didnt have time to adjust it so today i decided to do it. first take off the intake mine...
                    How to Check the Voltage on your Throttle Position Sensor.
                    After performing a swap, many times the throttle position sensor on the engine is broken, forcing you to use one from your old d15 or d16 (or whichever you pulled). The Honda TPS has three wires coming from it: green/white , a red/blue , yellow/white. Your primary focus will be on the red/blue wire, as this is the one that sends a voltage to the ECU telling it how open or closed your throttle is. The ECU expects .5 volts to be closed throttle and 4.5 volts to be Wide Open Throttle (WOT). The red/blue wire goes to pin D11 at the ECU. Rotating the TPS will change the voltage, when you take it off, you'll notice that the holes are slotted so it can move. If you are fortunate enough to have Hondata Datalogging or an Apexi V-AFC you can use their inbuilt functions to read the TPS voltage. If you do not have such a device, you can use a Voltmeter or similar device. Ground one lead on the chassis somewhere and use touch the (+) lead to the pin on the TPS (should be the center pin) and measure the voltage. Rotate it until it reads .5 volts, then tighten it down. Have a friend press the gas pedal to the floor and also check that WOT reads 4.5 volts.
                    For those interested with the other two leads, and I know there has to be someone out there. The green/white wire ties into a braided wire with the Intake Air Temp Sensor and the Heated Oxygen Sensor and they all run to Pin D22 on the ECU which is a sensor ground that reads less than 1 volt while the car is started. The yellow/white wire goes to pin D20 on the ECU which is a reference voltage, where it gives about 5v with the Key on and engine off.
                    S3-R
                    Stage3-Racing
                      EkRican beat me to it with a better version good luck
                      S3-R
                      Stage3-Racing
                        ima try now thanks guys
                          alex is prob right switch the 2 conections
                          My transmission's went 9's
                          http://youtu.be/z2PHemIp_Tg
                            i have the wires right there not switched and i cant seem to get a good reading i need to take my throttle body off and check it
                              wheres your location?
